Similar Content
By Toshko
Gtv 1.8 TS for sale
166000km
06/98
Very clean
Location Varna, Bulgaria
3500eur
By Toshko
Hello guys,
Have for sale very rare genuine OZ Zagato 17inch wheels made for Alfa Romeo 155T.I.Z japanese limited version in only 24 examples.
Details:
OZ RACING made in Italy
PCD 4x98
17x7.5J ET34.5
Central bore 58.1mm
georgiev.t@abv.bg
+359883361616
Varna, Bulgaria
By kunev
I'm selling two APEXi AVC-R (AVCR) electronic boost controllers, which I have bought second hand some time ago, but did not reach the point to use them...
Main features are:
two boost modes + OFF mode (boost regulated by wastegate spring) boost by gear boost by rpm with 500rpm intervals scramble boost with additional switch/button - temporary boost setting three modes of data presentation - analog, digital and graphical
Below one is modified in such way that cable to get out at the back of control unit instead of original at right side.
Price for it is 220 euro.
Price for it is 250 euro
By WillieNillie
Hi, i have some items for sale: i will be driving on the 10th of july down to england going through germany: hamburg, bremen, munster, dusseldorf into antwerpen, gent and finally euro tunnel to england: here is the map: https://goo.gl/maps/UkMe7YB48PDj8BJj8
if you want any of these items for youre car and can meet me on the way i will take them with me.
Complete Zender pedal set with footrest
Complete set of TS Bilstein B6 shocks (30 000 km on the front and rear) 1 rear failed and leaking and needs rebuild. the other 3 are great. 15% stiffer then stock, mono-tube design. probably the best set of shocks for the GTV. no springs or top mounts tho.
Painted 4 pot brembo 166 calipers in anodized red - might need a respray if you're picky. with adapters in aluminium also anodized red, Mtec Brera PCD redrilled 330x28 brake disc, with Stainless Steel Brake Pipe Set - Red from alfisti Incl. German TUEV/KBA certificate all bolt ons no need for any modification. all you need are some 330 PF pads and you have the best bang for your buck brakes for you're TS.
Retail worth: 600 euros if you where to buy this anywhere online to mix and match all these parts together.
Pm me your offers for these items.
only item i will send are the zender pedals, the rest you have to meet me.
